Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Civic Si Sedan - Shuttering/Vibration
Old 12-30-2013, 06:41 AM
philliwa's Avatar
Icon6 2004 Civic Si Sedan - Shuttering/Vibration
Hello Everyone.
Symptoms:
- 1600-2100 rpm the front end of the car will shake.
- this shake doesn't not occur in park or neutral
- it almost feels like you are driving on a washed out gravel road. but only in the front end
Checked Engine Mounts and they seem to be fine
This made me think it was either drive-axle related, however a mechanic friend said to have the CV Joints checked out as well.
Appreciate any help that comes of this.
Old 12-31-2013, 03:15 AM
philliwa's Avatar
Default Re: 2004 Civic Si Sedan - Shuttering/Vibration
So I believe it may be transmission issue. Time to hit the garage.
Old 12-31-2013, 06:30 AM
hondahead_dave's Avatar
they make an SI model sedan in 2004?
Old 12-31-2013, 03:16 PM
philliwa's Avatar
http://www.auto123.com/en/car-review...st?artid=21036
Yes they do.
Old 01-01-2014, 02:50 PM
Almighty-Si's Avatar
Left side axle
Old 01-01-2014, 04:11 PM
CandyRedRC46's Avatar
mine (2004 civic base model sedan automatic) is doing the same thing cruising around in drive at steady throttle 35-45 mph. if i let off the gas, give it gas or put in neutral it goes away. if i do nothing it lasts for what seems like an eternity. i cant get it to do it in 3rd gear.
Old 01-02-2014, 01:51 AM
philliwa's Avatar
Originally Posted by Almighty-Si
Left side axle
Going to the shop tomorrow. I will pray and hope that it is only the left side axle. Thank you Almighty.
Update when I get back
Old 01-02-2014, 10:48 AM
Okay I am waiting to hear a reply as my 2004 sedan is exhibiting the same symptoms.
Old 01-02-2014, 12:16 PM
Originally Posted by philliwa
the SI was only hatchback in '04, did they make it in another country? I was under the impression that the sedan came in '07 (which I have)
Old 01-02-2014, 04:52 PM
Let me clarify for philliwa as well
When in the inboard joint goes bad on the left side axle, under acceleration it feels almost like a shimmy/shutter in the bottom of your seat, basically when it happens you feel it on your back side.
When the inboard joint on the right side goes bad, you get a pretty nasty vibration and can usually duplicate and hold it by dragging the brakes while applying the gas. I usually test this side on a lift using this method and it shakes pretty violently.
philliwa, I read shutter yesterday and by reading the above you can see why I said left side, but don't rule out you may need both sides.
Also, these symptoms only apply if the vibration is occurring under acceleration. If this problem occurs at a particular vehicle speed and can be maintained if holding speed steady, it could quite possibly be a torque converter issue. Flushing the trans fluid sometimes will help the issue (when I say flushing I mean, draining and filling 3 times, 3 quarts each time) and I believe there is a software update that tries to help remedy this as well but that would have to be done at your local dealership. You would have to contact them about cost.
Old 01-02-2014, 06:55 PM
eviee1973's Avatar
For those who seem not to understand what a Canadian market model years 2004 and 2005 Si sedan is; basically a US market EX with daytime running lights, metric odometer, and low washer fluid level light without the side air bag option. Not as nice as the Acura EL, was the top level Civic sedan for those two years.
Old 01-04-2014, 04:25 AM
got ya, that's what I come to find out on the net, it was confusing me, as I have never seen one before. it is crazy how close to us Canada is, but the options of cars that we don't have is amazing, sorry for cluttering the thread with useless info.
Old 01-04-2014, 02:01 PM
any word back from the shop? diagnosis?
Old 01-22-2014, 02:44 PM
philliwa's Avatar
Hey guys. Sorry I hadn't been on the page for a while. Had some stuff come up with work that has kept me pre occupied
So. I just picked up my car from the shop today.
Ended up having new Front Axles replaced and a new Driver Side Bearing
Noticed improvement on some issues I hadn't really noticed.
HOWEVER
Still having the First Issue.
Now it's got me wondering...
Old 01-22-2014, 08:06 PM
philliwa's Avatar
I have a feeling this Torque Converter is the issue. I actually looked up a YouTube video of someone experience the issue. Exact same symptoms as I have. I am going to talk with the guy at the shop tomorrow. Find out costs etc.
Old 01-27-2014, 12:15 PM
Thanks man I would really appreciate it!!!
Old 01-28-2014, 08:09 PM
philliwa's Avatar
Turns out a new torque converter can be bought on ebay for $150 new or less with it being rebuilt/refurb
Also.
This what is happening to you ^^^^
A response from video
"Dr.Tranny Shudder Fixx works miracles..takes the shudder right out :]"
Old 02-03-2014, 07:04 PM
JJ291's Avatar
A chased a vibration in my 2001 Civic LX for a long, long time...lots of wasted $$. In the end I replaced the tie-rod ends and it vanished. I had checked them, they seemed fine but for whatever reason, that was the issue.
Old 02-03-2014, 11:54 PM
philliwa's Avatar
The fact that mine is only happening at certain rpm/speed is what is driving me nuts... Just can't keep dropping money to chase different ideas. Sucks
99JdmDc2
10
02-28-2008 09:53 AM
likenother
05-15-2007 08:33 PM
ohpooh2u
09-19-2006 08:24 AM
DC2SIR-G
02-23-2006 04:30 PM
CWBETB
04-28-2004 05:28 AM
Quick Reply: 2004 Civic Si Sedan - Shuttering/Vibration
