Code P0301 Misfire on Cylinder 1.. Help
Hi guys I really need some help here.. I have a 2002 Honda Civic LX and it broke down on me while I was driving it on the freeway and it hasn't started since. After having this checked my buddy came to see that the timing belt was worn and needed to be replaced. We replaced the timing belt and all other belts, also did the water pump and the camshaft position sensor, also replaced the spark plugs.
We tried starting the car and it will start but I have t floor it for it to stay on and the engine is really jumpy,I take my foot off the gas it shuts off. The CEL is flashing and we're getting a P0301 Code for a misfire on cylinder 1. We thought it could be the coil pack so we swapped it with another one from a different plug and same thing. Then we swapped the spark plugs to see if it was that causing the problem and same code... Please HELP.. |
Re: Code P0301 Misfire on Cylinder 1.. Help
did you get water or something other than fuel into you gas tank? other liquids don't burn like gas so when the engine starts and is running it will misfire.
what brand spark plugs are you using bosch ???
No other fluids in the gas tank but gas. The plugs are Autolite plugs that my buddy got at Autozone.
you shouldn't use anything other then NGK or DENSO in our cars cheap plugs can cause problems.
OK Im gonna change out the plugs today.. I'll get back to you guys.. Thanks for the help.
I put in the new NGK plugs and still having the same problem. Car only starts if I floor the gas and the engine is jumping and misfiring. As soon as I take my foot off of the gas the car shuts off. Anybody got any ideas or has anyone ran into this problem?
Help.. :hammer:
If i had to say i would same the car jumped time go back in and make sure everything is lined up along with the spark plug wires running from the distributor to the plugs.
We took everything out and checked the timing and the marks all lined up.. we even turned the crankshaft 2 turns counter clockwise until No.1 cylinder was at TDC of compression stroke with the timing marks aligned, and nothing. Theres no distributor just coils.
fuel pump work?
Yeah the fuel pump turns on.. I can hear it when i turn the key. Any other ideas?
Originally Posted by GeorgeBurns
(Post 42384891)
check that the injector clips are not corroded and have a proper connection |
The engine timing is correct we went in and double checked. I'm not sure about the injector clips so that is gonna be what I check next. Anyone else got any other ideas?
(Post 42386572)
Check compression as mention ^^ and the plugs, what cause the car to break down in the first place?
I dont know what caused the car to breakdown.. We're thinking it was the timing belt because it was missing teeth.. but after we changed it the car started misfiring. My first thought was that the timing was off but after double checking the timing we're stumped.
(Post 42387551)
does it idle at all or die soon after? |
(Post 42387551)
Originally Posted by 97twodoor
(Post 42387604)
I think you just answered your own question. The belt was missing teeth? So therefore it jumped and bent valves. Do a leak down check to confirm.
Originally Posted by Whatislove
(Post 42387602)
valve crash maybe?
(Post 42387672)
The car only runs if I floor the gas pedal.. as soon as I take my foot off of the gas the car turns off.
check your air intake, mas and iacv. can you swap injectors? how many miles on the engine, injectors might need to be replaced or cleaned. also, if your belt was missing teeth, you might have damaged valves, time to pull the head |
check to make sure you did not plug the map sensor connector into the TPS connecter or vice versa if they are backwards the car will start but only stay going if you floor it and usually die below 4000 rpm
(Post 42387604)
i agree! i guess in this case a simpler compression check is enough though. i'm surprised the mechanic didn't do one since was highly likely the valves would have gotten bent if the timing was wrong. |
Originally Posted by bomerman19
(Post 42390344)
