Clutch Issue...
Having a slight problem with my 01 Civic LX Sedan. When I go to start out in 1st gear, i have to let the clutch nearly to the top of travel before it engages. After I get going, seems to be okay.
The car has 250K miles on it, and I do believe the clutch has been replaced at some point. |
Re: Clutch Issue...
Check your clutch line to see if its leaking. Try re bleeding the clutch. Check your slave cylinder to see if its engaging enough.
