Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 honda civic issues w running properly
Old 06-30-2009, 01:19 PM
New User
lil_chop's Avatar
Default 2005 honda civic issues w running properly
so this is what happened and I don't know how to fix her
turn the car on and she idles funny after about 30 seconds she shuts off like she can't stay on?
I pulled out the coils and took the spark plugs out and they were a little wet...none the less put them back in and she ran for about 45 mins and as soon as I pulled her out of the garage she started chugging and shut of on me. I was getting cylinder 3 misfire for the 1st reading, I bought new plus NGK to see if it was the plugs as I needed new ones anyway but not changing the problem, she is sparking; I test the psi and she is reading about 180'ish on all 4 cylinders and I also checked the injectors, switched 3 & 4 with 1 and 2 after clearing the codes it still said 3 & 4 with different injectors. I had it checked out by a honda mechanic who can't figure it out either and I am lost for options! I was thinking there was a possibility that there may be bad gas as she has been sitting but there is no drain plug so it has to be syphered out which seems to be the next step. Any suggestions?
Old 06-30-2009, 01:21 PM
Sanji
toyomatt84's Avatar
Default Re: 2005 honda civic issues w running properly
Is the Check Engine light displaying on the cluster?
Old 06-30-2009, 03:56 PM
EM24's Avatar
u said ur comp reading was180?
Old 07-01-2009, 07:36 PM
New User
lil_chop's Avatar
the psi was 180
7thgenAccor
03-31-2018 09:29 AM
cjohnson11
Honda Civic (2006 - 2015)
04-19-2017 11:44 PM
ricknbird350
06-03-2009 08:20 PM
LudeBoyLeRoy
02-02-2004 07:59 AM
Buckshot
11-07-2002 08:16 AM
Quick Reply: 2005 honda civic issues w running properly
