2005 Civic ES2 k20a3 swap
#32
Re: 2005 Civic ES2 k20a3 swap
I finally got around to installing a TL shifter assembly. I think I'm going to redo my adapter brackets for it and slide it forward some. After that, I can redo the piece around it to do away with the gap.
#33
My old power steering pump started leaking on me so I went to pull a part and scored a replacement off of a wrecked rsx. Ol k20 has been pretty much hassle free since the swap though.
#34
SWEET! Great job man! I love custom cars. You can't buy anything like this from Honda. Like I said before, that engine looks stock in this car. Quick questions- So you hopefully never regretted doing the swap? Is the car reasonably quick now? Also, what's your gas mileage now? Thanks
#35
#36
Awesome. Thanks for responding. I think your car would probably get much better mileage with a 6 speed manual transmission, but I could be wrong. Also, I think that a K20A/A2/Z1 would also get better mileage from higher compression. Also, great job again.
#37
Another question- I know you had to mount the mounts for the K20, but did you use stock mounts? Also, which CV axles did you use? Sorry for all the questions, I’m sure you want to kill me for asking so many questions lol.
#40
Sanji
To be fair, you did weld in the stock chassis mounts from the RSX. Without drilling/cutting, a swap kit would be necessary.
#41
#44
#46
to be fair, you provided a link for a manual swap. There is a good bit of extra wiring to run the automatic. Plus little things like a/c lines, trans cooler, etc that aren't covered or bad info is provided. I covered most of the stuff in my posts but I didn't go in to detail on the wiring.
crazydjr26
14
08-10-2002 01:29 PM
ak_1
08-06-2002 01:56 PM
