05 civiv ex barometric pressure sensor
I got 05 civic ex automatic check engine light barometric pressure sensor
rpm to high in transmission to shift 2 o 3 is to high rpm 4500 I change many computers with one computer not more check engine and shift ok 3k rpm ok good work transmission but AC not work and gage temp engine not work, what I need to do I change 5 computers WHAT I NEED TO DO???? |
Re: 05 civiv ex barometric pressure sensor
First you need to slow down and form some better sentences tat don't have 4 question marks.
It's difficult to find out exactly what is is that you have done so far. You swapped out 5 different ECUs? All in the same day or over time? Did anything get fixed or worse after ECU swap? Please make a more detailed list. |
yes same day 5 diferent ECU only work good the transmission with ECU but not work ac and the other the ac no work and temp engine gage not work but transmission work perfect
