♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
#2501
Re: (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY »</TD></TR><TR><TD CLASS="quote">/\/\/\ 6.0L of pure inefficiency. Too bad the production model's bay will look more like this...
I owned that bay before I started my honda build. few motor mods and I could care less how cluttered it looked in there.
#2502
Re: (8 O ATE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8 O ATE »</TD></TR><TR><TD CLASS="quote">
thats where mine are
Have you had any problems with vibration? How did you mount them to the frame?
#2503
Re: (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">
Have you had any problems with vibration? How did you mount them to the frame?</TD></TR></TABLE>
no problems so far , but i am using rubber stand offs, rubber washers, 2 reg bolts, 2 nylon bolts, and lock washers all around , might say its over kill, but i dont want my dis-continued HID's falling off on the freeway somewhere
as far as mounting, the Catz hid's have 4 bolt hole mounts on each corner, so all i did was drill & tap mounting holes on the frame rails
#2506
Re: (H22EHSI)
im at a stage at my tuck where both the driver and passenger side shock towers are empty...
but not sure if i should go all out and put the engine harness behind the firewall. there is simply no space to drill a hole that big, with the engine in the way.
#2507
Re: (xDEFTONESx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx »</TD></TR><TR><TD CLASS="quote">im going to assume you didnt think to pull your dash out, pull your carpet back and drill a 2inch hole with a holesaw.
[jeff spicoli voice]"oh yeeeeaaaaaaaaa..........."[/jeff spicoli voice]</TD></TR></TABLE>
i didn't want the tuck to get that involved... but i found myself with extra time on my hands today so i went at it. dash is removed, heater box, a/c components are gone. gonna make myself a custom harness
#2508
Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 »</TD></TR><TR><TD CLASS="quote">
i didn't want the tuck to get that involved... but i found myself with extra time on my hands today so i went at it. dash is removed, heater box, a/c components are gone. gonna make myself a custom harness </TD></TR></TABLE>
Thats what im talking bout!
#2511
Re: (EF8kid)
i used two 1 inch holes side by side and used a factory harness gromment to seal it off
#2515
Re: (8 O ATE)
as far as mounting, the Catz hid's have 4 bolt hole mounts on each corner, so all i did was drill & tap mounting holes on the frame rails </TD></TR></TABLE>
I'll post pics of how I mounted mine when I return home from work and see how it appears to you
#2518
Re: (NAallTheWAY)
Y-49 FTW! I can't afford to get the car painted at the moment, and there is rust to be dealt with before that happens. The bay will be left primered as I shave and fill as time allows. Over winter I want to learn how to weld so I can fill in some holes.
#2519
Location: 9/11/01 WTC Never Forget, United States Of America
Re: (CRXed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXed »</TD></TR><TR><TD CLASS="quote">
Finally get to start her this week!
I'll finish the rest of the wire tuck during the obd1 conversion.</TD></TR></TABLE>
Nice very nice damn that first gen b16 is clean as hell
Bit off topic but does anyone have a front heat shield for a stock ITR header they would like to sell me?
#2521
Re: (PandaHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch »</TD></TR><TR><TD CLASS="quote">Chase, you sir are a tool hahaha</TD></TR></TABLE>
hahaha what i aint hatin, Jonah is cool. I just wanted to sing. Thats all i want!
#2525
Re: (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY »</TD></TR><TR><TD CLASS="quote">This car was up for sale a while back, I guess he decided to keep it and upgrade to itb's.
thats mine
yea i upgraded.. now im goin back to an RBC manifold/CF Hood.. the car is getting traded for a Hype R hopefully..
thats mine
