Post up pictures of your BIG BRAKE KIT!!!!
#152
Re: Post up pictures of your BIG BRAKE KIT!!!!
Can anyone confirm that the RSX Type S front calipers are the same as the S2000 front calipers? is so, why are soo many people utilizing s2k calipers over the rsx type s ones?
#153
#155
Ek Forever y0!
S2000 rotors don't have the proper hub for civics/integras. The s2000 and RSX-S rotor are the same diameter, but the RSX-S rotor has the proper sized hub. That's why we use that for hybrid setups.
I'm currently running an 11.8" RSX rotor with s2k calipers:
Old/New rear:
Old/new front:
New rear almost done:
Complete and bedded in front setup (After we finally wore off all the paint:
Old/New rear:
Old/new front:
#156
On my itr I have spoon calipers:
On my ef I have itr brakes:
And on my s13 I went with evo brembo:
Then I switched to wilwood / defsport / skullworks:
#158
They're all big compared to what came on the cars (except for the spoon stuff - which is just physically bigger but uses the same pads).
#160
#163
can get them on ebay under $600 and i assume that if you know someone running the yard or you work where the car is being parted, you can get them a lot cheaper
#166
Rotor DTC HAWK 12.1875 x 1.25'' (310mm X 32mm) thick, 2 pieces rotors bolts pattern 8x7
949 racing 6UL 15x8, offset 36mm Gen 2
Rotor Hat from Wilwood, 8bolts over a 7'' circle
Wheel spacer 19mm with a shim hat, or 25 without
Monoblock Performance Friction Caliper model ZR41
do not care about the cross over line, have been change, it's now below and bleeders are now on top
