Official Engine build up Pics Thread
I havent seen a thread like this. Post up our engine shots No I dont wanna see your engine in your car. Post up pics of the engine your working on, on your engine stand, or just laying around, etc... NO ENGINE BAY SHOTS!!!!!!
1 Post
Re: Official Engine build up Pics Thread (EF Two)
i guess i'll post some.. just for *****...
THIS:
will be replaced ASAP with:
My H22a, that i personally built in my basement/garage.
Originally put together from 2 blown h22a's i had.. final motor consists of a JDM H22a Head <- and a USDM H22a4 Block <-
(just some pix that i have uploaded):
totally stripped down, cleaned in & out.. and finally alil paint
yummy vs. yucky
DIY Port & Polish (with tools i had around the house):
Final product:
After ^^^ that took place all the valves were removed and totally cleaned.. then every valve/valve seat was lapped and grinded for a perfect seal!
Motor Assembled:
with:
ARP Headstuds
Cometic High Pressure Head-Gasket
Billet Cam Seal
All new OEM Honda gaskets, IM, Exhaust, TB etc etc..
tranny is on the way.. JDM H22a (non LSD)
will be mated with an ACT Extreme (stage 3) Pressure plate and a 6 puck disc
and a brand new ACT SFI 8.0lb Flywheel (newer version of Pro-Lite)
will all be going in this!: (my baby)
my 1990 Honda Accord EX-R (CDN) 4-door, 5-speed
once my motor is DONE and RUNNING.. im am biting the bullet and immediately buying a bare H22 Block and having Darton M.I.D Sleeves installed ASAP.. to eventually be used for BOOST! (wish me luck)
my whoring is done
THIS:
yummy vs. yucky
Final product:
Motor Assembled:
with:
ARP Headstuds
Billet Cam Seal
my whoring is done
Re: Official Engine build up Pics Thread (4genaccordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4genaccordfreak »</TD></TR><TR><TD CLASS="quote">
looks like you need to polish that up a bit more and have it bench flowed
1 Post
haha ^^ that was all done with a dremil tool and a bunch of different bits.. the finest sanding bit i had was 120grit.. i could have taken it to the shop i work at and done it much better but.. **** it.. motor is all together now so..
Re: (4genaccordfreak)
well i blew this motor up, it went like this. 1. got it from a used japan engine comp.
2. boosted it 7psi 3. ran it really hard 4. blew it up 1 yr later
but new motor will be in my car in 2 weeks ill go up to the machine shop and take pix.
Re: (EF Two)
That's where she sits for now! B18a block, P72 head, ITR .25 pistons, ARP rod bolts, ACL bearings .. many other goodies not pictured awaiting install
Re: (D-series ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-series ninja »</TD></TR><TR><TD CLASS="quote">ugly gsr
WTF happened, looks like it was grenaded
Re: (itsJDMyo)
not exactly progress pics, but I have pics of my motor when I first got it.
JDM CTR motor, wrecked in a circuit race probably.
damage to the tranny casing.
The tranny case, and transmision bearing were replaced with brand new parts from Honda, no progress pics though.
Modified by Kouki-EK9 at 8:57 PM 7/10/2005
Guest
Posts: n/a
Re: (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">
WTF happened, looks like it was grenaded</TD></TR></TABLE>
we came to the conclusion that the banjo fitting on the fuel rail wasnt tightened enough bc it was really loose when i was lookin **** over ( takin it apart) so i tink it was pissin fuel on the exhaust and just went up like hiroshima
4genaccordfreak
10-06-2008 05:54 PM
