how to remove pinstripe from integra?
Old 07-13-2001, 09:10 PM
Lonerider's Avatar
Default how to remove pinstripe from integra?
hey
anyone know a safe and relatively fast way to remove the pinstripe off of an integra?
Old 07-14-2001, 08:58 AM
LegendLS95's Avatar
Default Re: how to remove pinstripe from integra? (Lonerider)
I hear a hairdryer works.
Old 07-14-2001, 05:48 PM
BoM
BoM's Avatar
Default Re: how to remove pinstripe from integra? (LegendLS95)
i left my car in the sun....and then used my nails and stratched it off...and pulled it off....have a buncha friends do it...i had 3 plus me....we had each corner and raced...who gets more of it off...
Old 07-15-2001, 07:25 AM
New User
tsjag17's Avatar
Default Re: how to remove pinstripe from integra? (bommiE)
how do u get the pinstrip off if it is painted on?
Old 07-16-2001, 12:34 AM
OneThirtyEight's Avatar
Default Re: how to remove pinstripe from integra? (tsjag17)
I belive somewhere make a kit for removing them.
Old 07-17-2001, 11:22 AM
New User
Phat Corolla's Avatar
Default Re: how to remove pinstripe from integra? (97blackteg)
I have been thinking about removing mine too...there's a little bit missing on one side. I like the hairdryer idea, but would it wreck the paint too??? that would seriously suck. I want to be as sure as possible that it's safe before i do it, since i can't afford a new paint job. Peace out
Old 07-18-2001, 07:53 PM
bocian's Avatar
mine weer pissin me off so i got the taken off, just get someone (best if you know them or can be there when they do it) to buff them out, it'll get them off and make your car all shiny
Old 07-18-2001, 07:57 PM
nerdish's Avatar
Default Re: how to remove pinstripe from integra? (bocian)
I don't think it would hurt the paint because the pinstripe would be able to be torn off before it got /that/ hot. Just don't hold the hairdryer in one spot for too long a time and I'm sure you'll be fine.
Old 08-15-2001, 09:44 AM
miketegra's Avatar
I did this on my 94 GSR and my 97 Prelude.
Use a heat gun or hair dryer.
Heat up a 6 inch section of pin stripe (starting from an end). Carefully, using your fingernail, lift up the fitst 1/4 - 1/2 inch of pin stripe starting on the end. Slowly pull on the pin stripe and point the hairdryer about 2-3 inches ahead of where the pin stripe is separating from the car as you pull it. If you point the heat gun directly at where it is separating from the car, it will melt the pin stripe and it will come off in 1 in sections, not 12 inch sections.
The whole process is easier if you leave the car in the sun to heat up first.
I would not do this to a car that was more than 2-3 years old for fear that you may see a difference in the paint color or a ripple in the clearcoat.
v8 integra
05-19-2008 02:50 PM
-Gambit-
12-12-2005 12:37 PM
jweezy225
07-11-2004 01:02 PM
Dc2 Powered
02-14-2004 11:50 AM
getfast
24
11-27-2001 06:53 PM
Quick Reply: how to remove pinstripe from integra?
