Any Suggestions On how To Hide Washer Bottle Tubing? - Honda-Tech - Honda Forum Discussion
Closed Thread
Old 07-19-2017, 02:05 AM   #1
Default Any Suggestions On how To Hide Washer Bottle Tubing?
Hi,
Has anyone any photos of how they tucked the tubing that runs from the bottle and along the top of the strut tower from, in the factory position.
Thanks,
skyviewLA01 is offline
Old 07-19-2017, 09:16 AM   #2
O.G. triple O.G.
NVturbo's Avatar
Default re: Any Suggestions On how To Hide Washer Bottle Tubing?
The stock tubing will likely not reach. Even if it does, replace it with 1/4" clear tubing, found at your local hardware/home improvement store. Run it along side the hood release cable, within the driver side front fender. You can exit into the engine bay near the wire harness plugs, at the driver side strut tower.
NVturbo is offline
Closed Thread
Difficulty flushing brake fluid chowderhead Honda Civic / Del Sol (1992 - 2000) 1 09-11-2017 04:24 PM
Engine Oil is flowing into coolant reservoir bottle 99Accord1 Honda Accord (1990 - 2002) 44 03-02-2017 11:15 AM
brake fluid replacement. prodjay10 Honda CRX / EF Civic (1988 - 1991) 4 05-02-2016 08:25 AM
Default [FAQ] How-To: Change your Civic Manual Transmission Fluid imadigitalgod Honda Civic / Del Sol (1992 - 2000) 187 04-23-2016 08:08 AM
Hytech piping size question Rasmusm Honda Prelude 3 04-18-2010 03:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
