94 Accord J32 6spd
#27
Re: 94 Accord J32 6spd
I'd love too see more 5th gen owners attempt this swap, as you can see its not impossible :p
#29
2003 CL Type S ECU and the clutch master cylinder i have its off an AP1 but you can retain the factory accord CMC, that has nothing to do with the swap really...
#31
Im in Cali so go figure lol but if you're worried about emissions than this ain't the swap for you since the evap system on the CL-S its a bit complex and getting it to work would be a PITA... to me it was a headache and waste of time. The state refs are too strict nowadays and would fail you anyways. :p
#32
If im not mistaken, On a OBDI, they just stick the pipe up the exhaust and measure the amount of gasses the car is putting out. Shouldn't be to hard to pass as long as the motor is stock....right?
What mounts did you order from hasport and how did they have to be modified to work?
#35
FFC makes an adapter for the 5th gen accords, well a prototype for now, hit them up for more info www.fatfourcustoms.com
2003 CL-S harness
2003 CL-S harness
#37
how did you go about connecting the cl-s engine harness to the factory cd5 inside harness? was there an adapter that you found?? same question for the ecu..... and also did you have any problems with the oem accord shifter cables?
#40
EGJ mounts, i can't tell you exactly how much they were modified, you are trying to make something designed for another chassis fit into yours so you will see what needs to be modified while you're at it
hasport would probably make mounts for prelude/accords if there was more demand...
thanks
#41
Random update:
got another baseline with the Comptech icebox in september, it made 219whp/211tq, i lost 2whp and 2tq with the comptech intake :p
i went and looked into a different intake manifold and came across a J35A7 off a 08' Ody Touring...
used my k2h adapter, h22 70mm tb and put back my 3" intake... then went back for another baseline
final numbers were 241whp and 221tq
Before:
After:
Before:
After:
#45
yeah youre right it does. it looked real good in your bay, but if it isn't doing anything power wise then its good you got rid of it.
#47
I think the car is a true sleeper, the exterior its all beat up, dents all over, paint its fading :p
it was a LX with ABS chassis, got rid off the crappy abs, ac, heater and ps... the interior is gutted.
the plan is to get headers, 3" exhaust and maybe a TL-SH IM to be around the 250ish whp
the RX7 suspension won't fit right in, lots of fab work was needed specially for the front.
the wheels i had on the pics belong to my other k2h accord...
Sprint Hart CP-Rs
Sprint Hart CP-Rs
