92-93 INTEGRA GS-R DB2 THREAD
#302
Genetically Gay
Re: 92-93 INTEGRA GS-R DB2 THREAD
gave a fresh washed.got those tsx on.my review!!this car is consider to be classic..it's about 20yrs old.. has the light stiff suspension.rear anti roll bar/front double wishbone/1.7liter Vtec.high rev race oriented motor.short gear to weight ratio.so that's about 50/50 on da chassis.only total 3000 were made in japan 92/93 gsr.even though is front layout honda did good on this one.who owns one of these is pretty lucky.
#304
1992 Integra GSR with a pair of jdm one piece headlights w/ 4.7k Raybrig lights, jdm fenders, lowered on Tein Super Streets, Spoon strut bar, Spoon shift ****, personal steering wheel, and rota grids. Pretty much stock with a minor mods. Stock motor with a custom flow master 2.5 headerback
#305
Found this FS on local CL.......I dont have the funds for it right now or I would pick it up, always wanted one!
Please dont PM me about it, its not mine, if you live in Seattle the add is easy to find.
#310
#314
Whoa, didn't know this thread existed! Sadly looking through my Photobucket, I don't really have any decent pics of this car all together. It's a work in progress as of now.
The most put together the car has been in a year or so
Most current pic of bay
Suspension
Parts list so far
Engine
JDM B16A Block (I now have a B20 bottom end that I'm working on as well)
P72 GS-R Head
Rich Porter TD44 Distributor
Skunk2 Tuner2 Cams
Titanium Retainers
Dual Valve Springs
Skunk2 Pro Series Intake Manifold
Skunk2 Alpha Series 66mm Throttle Body
Hondata Intake Manifold and Throttle Body Thermal Gaskets
Go Auto Works Intake w/Circuit Hero V Stack and Vibrant Filter
Skunk2 Composite Fuel Rail
Acura RDX Injectors
DevSport Fuel Lines
Fuelab Fuel Pressure Regulator
Russell Inline Fuel Filter
B&M Fuel Pressure Guage
DevSport PS Loop Line
Endyn Oil Catch Can Kit
Endyn Timing Belt Tensioner
ATI Fluidampr Street Crank Pulley
Speedfactory Coolant Filler Neck
Spoon Radiator Cap
RyWire/CSF Tucked Radiator with -16 AN fittings
Aeroquip Coolant Hose/-16 AN Fittings
PLM Toda Rep Header
PLM Test Pipe
Tanabe Touring Medallion Exhaust
T1R Exhaust Hangars
G2 Power Steering Rebuild
DevSport Power Steering Line Loop
Hondata S300 v3
RyWire Tucked Harness
RyWire Charge Harness/Ground Kit
Odyssey PC680 Dry Cell Battery
Baffled Oil Pan
Spoon Sports Magnetic Oil and Transmission Bolts
Spoon Sports Radiator Cap
Suspension/Brakes
Fortune Auto 500 Series Coils
Swift Springs 12k front/10k rear
Vision Strut Tower Bar
Miracle X Bar by Next
HardRace Front Upper Control Arms
Cusco Rear Upper Control Arms
HardRace Roll Center Adjusting Lower Ball Joints
ASR Rear Sub Frame Brace
ASR 24mm Rear Sway Bar w/Spherical Endlinks
ASR Rear Lower Control Arms
Wheels/Brakes
15x8 +25 Enkei 92’s
205/50/15 Falken Azenis RT615k
EBC Green Stuff Pads
Stop Tech Blank Rotors
Chase Bays Steel Braided Brake Lines (wheel wells)
Rywire Fittings/Brake Tuck (Using Eastwood hard line)/ABS Delete
Interior
Nardi Deep Corn Sport Rally Black Edition 350mm
NRG Short Hub/Version 2 Quick Release
Spoon Sports Duracon Shift ****
B&M Dual Bend Short Shifter
Circuit Hero Shift Extendor
Kenwood KDC-X998 CD Player
Pioneer A Series 4 way 6.5” speakers
Exterior
JDM One Piece Headlights
OEM Sunroof Visor
OEM Rear Wiper Delete
JDM Power Folding Mirrors (not installed yet)
OEM Arizona Sunfade
Link to build thread in signature if anyone cares
Let's see some more DB2's
Suspension
Parts list so far
Engine
P72 GS-R Head
Skunk2 Tuner2 Cams
Titanium Retainers
Dual Valve Springs
Acura RDX Injectors
DevSport Fuel Lines
Spoon Radiator Cap
PLM Toda Rep Header
PLM Test Pipe
T1R Exhaust Hangars
Hondata S300 v3
Baffled Oil Pan
Suspension/Brakes
Wheels/Brakes
15x8 +25 Enkei 92’s
Interior
Exterior
OEM Sunroof Visor
OEM Arizona Sunfade
#319
jdmjunkie562
11-13-2008 10:25 PM
