Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Water leak on 2013 Crosstour.
Old 05-18-2017, 05:08 AM
Kee kee's Avatar
Post Water leak on 2013 Crosstour.
Ok folks I'm having a bit of a problem with my 2013 Crosstour. I have water leaking and wetting the carpet on the drivers and passenger side rear carpet. I think I have had this problem since it was new but the car only has 10,000 mile as on it and stayed in the garage all of its life. I have checked the sunroof drains, they are fine and drain behind the front tires. I cannot feel wet carpet on the hump between the sides but both rear pans are wet. I have weather tech mats in it and only found it after investigation into a muggy smell in the car. I say I've always had it because I noticed this same smell when we first bought the car new but it went away quickly and chalked it up to new car smells. Your help will be appreciated.
Old 05-19-2017, 08:47 AM
DCFIVER's Avatar
Default Re: Water leak on 2013 Crosstour.
Does that vehicle have rear AC?
Old 05-19-2017, 12:29 PM
Kee kee's Avatar
It doesn't have rear air but the duct work does come out of the console to the passengers. There is also a center hump and it wasn't wet at the hump, just in the floor pans. I also climbed under to look for drain holes and there is one under each pan toward the edge of the car but I'm not sure that they aren't to drain the chassis. I stuck a screw driver in them and hit metal about an inch above.
Old 07-29-2018, 05:40 PM
OfficeLinebacke's Avatar
So what did it turn out to be in the end?
lilmarcEH3
02-03-2011 06:12 PM
Jhonny Ricer
11-28-2006 07:49 PM
djdizzo
01-22-2005 04:10 PM
Quick Reply: Water leak on 2013 Crosstour.
