Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Transmission fluid change
Old 08-18-2011, 01:27 PM
LittleGuy1972's Avatar
Default Transmission fluid change
Hi all,
First time poster but long time reader of this forum.
I have a 2005 Honda Accord EX V6 leather with 120,000 miles on it; original owner. I had my transmission fluid changed for the first time at 100,000 miles while I was having my timing belt and water pump replaced. At the time the mechanic didn't realize that it was the first transmission fluid change otherwise he would not have drained it.
Since then every time I get my oil changed at a different service center they try to talk me into having the fluid suctioned out of the transmission to ensure 100% removal of the fluid. I keep telling them I don't want it done but want to be sure I am doing the right thing. They keep telling me the fluid is black instead of red. I can remember being a kid and my dad telling me that if you don't get it changed by a certain point you can actually do more damage than good.
Thoughts? Thanks in advance for your advice.
Regards,
Brian
Chapel Hill, NC
Old 08-18-2011, 02:07 PM
BLKFLSH's Avatar
Default Re: Transmission fluid change
I would do simple drain and fills (three quarts at a time), until the fluid is red again. I would definitely not allow someone to do a "power flush" on the transmission. You don't want to force the fluid through the small passages, but a simple drain and fill would not do that.
Old 08-18-2011, 02:12 PM
Thanks, BLKFLSH.
Is there an online resource to find the procedure for a DIY fluid change? Is there a filter on these transmissions? Should that be changed too?
Brian
Old 08-18-2011, 03:56 PM
BLKFLSH's Avatar
Yes, there is a filter. Yours is probably just a hunk of metal at this point. Dealerships don't usually have the filter in stock, because they rarely change them. Apparently, Honda doesn't think the filter needs to be changed, but I disagree. I order my parts online, and change the filter and fluid myself. I'm sure there is a link with a how-to somewhere, but I don't have one handy. I have the recall (jet kit) installed on my tranny, so I just unbolt the bracket for the jet kit, pull the end of the pipe out, then fill through that hole. I may be able to find a how-to with a search.
Old 08-18-2011, 04:59 PM
BLKFLSH's Avatar
I found the link on changing the filter. Don't remember if it has the drain and fill included or not. Here it is
http://www.driveaccord.net/forums/sh...ad.php?t=13804
Old 08-19-2011, 09:05 AM
Thanks for finding that for me, BLKFLSH, I appreciate it.
I am going to drain, fill, drain, fill, drain, fill this weekend to get a good amount of new fluid into the transmission and torque converter and go from there.
Have a good weekend!
cabtank@aol.com
06-11-2019 08:37 AM
sadakoyamahonda
12-02-2018 09:42 AM
DennisWaller
02-29-2016 02:10 PM
kramun
03-17-2014 08:59 PM
dan_g
27
10-05-2009 03:06 AM
Quick Reply: Transmission fluid change
