Installing Subwoofer
Is it possible to install a subwoofer using the stock Honda Headunit on my 7th gen accord sedan? It has the 6 disc cd change. Or do I have to install an aftermarket headunit? I'm looking to get the Infinity Basslink.
If it is possible..is it possible to hook up a 4-way amplifier for my speakers using the same stock headunit?
Any information would be helpful..thanks!
well i got everything set up at bestbuy cuz they know what to do. and yeah i got like an adapter sort of thing that i needed inorder for me to use my subs with a stock head unit. and the adapter thing was placed in the trunk right under the rear speakers.
Re: Installing Subwoofer
Be careful, many of these guys are strictly car guys but not car audio guys!
You can run off stock headunit but the amp output is a lot weaker than with an aftermarket headunit installed. Most audiophiles would consider this a waste of money since you really are limiting your system immediately from the source.
JL CleanSweep does work well and is maybe the easiest way to keep your stock headunit while maintaining performance from speakers/subs.
If you are serious about your system I would suggest a few weeks on the www.caraudio.com forums.
your going to need an amp, a wiring kit,
remote and rca from the cd player ran to the amp.
power wire through the firewall and then hidden by the trim .
ground wire no longer than 18 inches long then speaker wire to your amp.
for clarity you need an aftermarket reciever with rca output.
Sorcin
05-17-2010 07:36 PM
davejj40
Audio / Security / Video
03-09-2005 07:34 PM
thugsoulja
05-06-2004 09:45 AM
