Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2009 Accord 2.4L #2&3 misfire code under load.
Old 04-24-2017, 12:57 PM
lamal92's Avatar
Default 2009 Accord 2.4L #2&3 misfire code under load.
I had switched coils,plugs,injectors & did compression checked. Fuel pressure is normal. Still 2 & 3 miss. Honda dealer said it's because of a aftermarket starter which causes interference to ECU.
Old 04-24-2017, 01:43 PM
Mrprofits213's Avatar
Default Re: 2009 Accord 2.4L #2&3 misfire code under load.
hello. You should post this at the Accord section. This is for Acura Integra.
Old 04-28-2017, 08:44 AM
NatBx's Avatar
Starter should have nothing to do with misfire, all it does just starts the engine and the ECU should take over. By advice is pickup up in line ignition tester and check for spark, if you do not have spark, check distributor. Then check your timing and do distributor timing adjustment.
You mention compression check, I am assume it is good? If not do a leakdown. If the compression is fine, then it is either your timing or distributor.
Old 05-13-2017, 05:46 AM
aergunnr's Avatar
You may want to take a look at some of the TSB's for your car. My 09 V6 Coupe is in the Honda shop right now getting warranty work due to this. Time is running out out it though. I think this is the final summer for the extended powertrain warranty for 09 models...
Here is the TSB affecting mine. MIL Comes On with DTCs P0301 thru P0304 ? 2008-2012 Honda Accord | honda.oemdtc.com
crxpwr1
08-25-2019 11:46 AM
barefoothonda
08-21-2018 07:31 AM
rome90731
06-20-2018 06:08 PM
Rick_Kaz
12-21-2013 10:25 AM
ohiojack
11-04-2007 04:40 PM
Quick Reply: 2009 Accord 2.4L #2&3 misfire code under load.
