2005 accord power windows do not work only drivers window
Only drivers window rolls up and down. Checked fuses and drivers window fuse reads +12v and the rest of the windows do not work and show no reading when tested. Pulled those fuses and still good. Somehow the rest of windows are not powering up. Please advise.
Anthony
Anthony
Re: 2005 accord power windows do not work only drivers window
Youll need a wiring diagram in order to troubleshoot this issue.
This issue is generally due to the driver's door multiplex control unit (mcu). There are other threads regarding the same thing.
To test it, pry the driver's door master switch out, then use a separate piece of wire or a paper clip and jump terminal no. 1 (black wire) to terminal no. 3 (white/green wire). White/green is a wire with white insulation and green stripe.
If the other windows (i.e., passenger windows) work after this, this confirms a faulty driver's door mcu.
crxaddikt
12-07-2016 01:12 PM
Rayz_Si
05-10-2008 02:29 PM
Myh4tch
10-27-2006 12:12 PM
civicseth
12-14-2005 10:18 PM
