2004 Accord Serpentine Belt Slides On Tensioner
Solved: 2004 Accord Serpentine Belt Slides On Tensioner
Hello all, I hope someone has dealt with this problem before and has a solution. I have a 2004 Accord EX that has been a very dependable car until recently. The serpentine belt keeps coming off of the pulleys. So, I did what I thought would solve the problem. Thinking the tensioner was worn out, I replaced it will a new one along with a new belt and tensioner wheels. This did not solve the problem but at least it eliminates the tensioner as the culprit. Every time I put the belt back on I make sure that it is on each pulley and the grooves are lined up. I center the belt on the the tensioner wheel and it all seems good. Once I start the car the belt will immediately move on the tensioner to where it is just about to come off of the wheel. Eventually it will come off, however I still drive it and I frequently have to put the belt back on. The only thing out of the ordinary that I notice is that the crankshaft pulley seems to wobble a bit. I have no idea if this had wobbled in the past or not, but the wobble could be enough to make the belt move on the tensioner. About 8 months ago, I replaced the timing chain and removed the crankshaft pulley in the process but remember torquing it back on to spec so I doubt that it has come loose. The only thing I can think of to temporarily fix this would be to add washers and a longer bolt to the tensioner to bring the wheel farther out. This may be hard to accomplish since the tensioner bolt is reversed threaded and finding a longer one might not happen too soon. I have attached an animated gif and a You Tube video link.
<iframe width="560" height="315" src="https://www.youtube.com/embed/3f6YpvstbwY" frameborder="0" allowfullscreen></iframe>
https://youtu.be/3f6YpvstbwY
New and old Harmonic balancer next to each other.
The old harmonic balancer came apart while I wiggled it with my hands. This is what caused it to wobble. The wobbling is what made my serpentine belt slide off of the tensioner. There is a rubber band inside the balancer designed to take out some of the vibration. Luckily this didn't come apart when my wife was driving on the freeway at 3,000 rpms.
Re: 2004 Accord Serpentine Belt Slides On Tensioner
Alex, the pulleys were not seized. The harmonic balancer is actually 2 pieces of steel with rubber between the. If the rubber wears out the pulley starts to wobble making the belt slip.
Jason777
07-07-2014 02:06 PM
famfive
07-25-2010 08:29 AM
