Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
NGK or Denso plugs?
Old 08-20-2009, 12:12 PM
StockAccord's Avatar
Default NGK or Denso plugs?
If I were to replace my plugs, what should I go with? NGK's or Denso's? (iridiums of some sort).
Old 08-20-2009, 01:13 PM
Janet@bisimoto's Avatar
Default Re: NGK or Denso plugs?
I hope this will help you. Here is the link: https://honda-tech.com/forums/acura-integra-type-r-8/spark-plugs-ngk-vs-denso-vs-bosch-136130/
Old 08-20-2009, 02:18 PM
BLKFLSH's Avatar
I think the reason the Denso and NGK iridiums are more expensive, is because they are "long life" plugs. They are supposed to last 100k miles. My 03 V6 came with the long life iridium Denso plugs, and the engine is still running as smooth as ever at 67k miles, with those original plugs. I took a couple of them out, just to check their condition, and they look fine. I keep thinking about changing them before 100k miles, but haven't done it yet. I don't think the platinum plugs are 100k mile plugs, so while they may cost less, you will be changing them more often.
Old 08-20-2009, 03:21 PM
i just need to pull mine out, check them, make sure the previous owner didn't put some goofy plug in the car ya know. Like diamond fire, or Split fire. I want OEM plugs.
Old 08-20-2009, 04:08 PM
Vietnamese!
ALLxMOTOR EG's Avatar
NGK works fine with me no problem.
Old 08-20-2009, 05:53 PM
I've always been a NGK kind of dude. Denso works too, but just never ran them for no apparent reason. I wonder what Honda put in from the factory... denso or ngk.
Old 08-21-2009, 01:41 PM
BLKFLSH's Avatar
My 03 V6 had the Denso's as original plugs. They are still in there, at 67k miles.
Old 08-21-2009, 02:10 PM
baz_ctr's Avatar
i have used denso iridium plugs alot in my Honda's i like them never used ngk
Old 08-21-2009, 06:10 PM
ok, so looks like Denso was probably the OEM supplier.
Old 08-21-2009, 08:56 PM
BLKFLSH's Avatar
I'm pretty sure they still use both NGK and Denso. I know they've used both Denso and Delphi alternators, so parts are not all exclusive to one manufacturer.
Old 08-22-2009, 04:24 AM
ok. so which ever one I can get easier/cheaper if the plugs need changed. Hopefully they don't need it, and the previous owner resisted his urges to put in spark plugs that he saw on a info-mercial.
Old 08-22-2009, 09:35 PM
chinochanginc's Avatar
use w.e. the owners manual calls for..
Old 08-24-2009, 09:53 AM
ch0baca's Avatar
honda uses denso parts
lawrencelomanon
Honda CR-V & Element
11-15-2017 10:37 AM
TravisCadello
14
02-04-2009 11:41 AM
SloCivicHMM
04-04-2003 09:06 AM
2k1 GSR
01-12-2003 02:33 AM
HX_Guy
10-23-2001 08:19 PM
Quick Reply: NGK or Denso plugs?
