Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord stuck on low beams
Old 03-27-2017, 07:09 PM
Speedy5966's Avatar
Default 03 Accord stuck on low beams
Hi! Newly acquired 03 Accord. When I switch between high and low beams, the high beam indicator on the dash comes on in high beam, but the lights stay on low beam. There is no change at all in the lights. Also, with the ignition and lights off, if you pull back on the dimmer switch, it's the low beams that come on. I figure it's the switch, because the low beams stay on when you go to high beams. If the low beams went out, but I had no high beams, I'd figure it was both high beam bulbs. I just don't want to go to the work and expense of replacing the switch, and have it not fix the problem.
Thanks!
Old 04-11-2017, 08:50 PM
cjay__19's Avatar
Default Re: 03 Accord stuck on low beams
check the bulb first im not 100% but I think that's a dual filament bulb and it may be a coincidence but both burned out.
Old 06-08-2019, 10:51 AM
KarazeeeKay's Avatar
Default Re.. I have an 05 Honda Civic DX High beams and indicator not working..
My indicator and highbeams just stopped working the other night on my 05 Honda civic DX.. Do I have relays to it?
dlric
17
04-15-2016 03:36 PM
trinib20
11-24-2009 02:34 AM
rezzarect
07-28-2007 08:22 AM
Jhonny Ricer
32
03-02-2007 05:59 AM
bhulett
06-02-2006 05:21 AM
Quick Reply: 03 Accord stuck on low beams
