Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
wont shift out of park console lights dont turn on, no window control
Old 11-07-2012, 09:36 AM
dantheman86's Avatar
Default wont shift out of park console lights dont turn on, no window control
First I had a problem winding up and down the windows from the driver's side. So I ordered the Windows Master Switch (still in the mail). I touched some metal contacts together on the old master switch in an attempt to wind the windows up becuase its going to snow then smoke came out, the board burnt. I am getting a new Window Master Switch so I am not worried about that part. Now the car will not shift out of park and the console lights will not turn on. The brake lights work, I can drive if i take a screw driver and press down the slot thing. What do I do to fix the lights and shifter problem. It is a 2003 Honda Accord with Automatix transmisison and V6 engine.
Old 11-07-2012, 09:37 AM
Default Re: wont shift out of park console lights dont turn on, no window control
yes, I know you are going to say im an idiot
Old 11-08-2012, 12:13 AM
I checked all the fuses in the drivers side panel and under the hood, they are all good. the turn signals do not work, i dont hear clicking when i turn them on
Old 11-09-2012, 10:46 AM
h0p3l355dork's Avatar
Check the small lights fuse on the passenger side. I had that happen to me before and it would not shift out of park as well.
Old 11-09-2012, 03:06 PM
Lost Again's Avatar
As asked before, do the backup/reverse lights work? Yes, no....and the additional info (shorting out the board) would have helped in your other posts.
Old 11-12-2012, 03:21 PM
thanks for all the input, ive been posting on two or three forums, it is a lg meter fuse. I dont know how i tested it good the first time. most likely the multimeter ends were touching to make a circuit. I replaced the 7.5 amp fuse and the dashlights came back on as well as being able to shift gears. Also replaced the master window switch. $206 at a dealer but when you cant wait another day you have to do it. The passengers window still does not wind down. and the clicker does not work.
rrepking
01-06-2015 02:08 PM
SlamsItIn
08-17-2013 09:38 AM
Mesek_oner
06-02-2013 06:33 AM
zachgk7
03-12-2007 07:07 AM
stupidwhitecat
11-05-2005 04:26 AM
Quick Reply: wont shift out of park console lights dont turn on, no window control
