wiring mess! NEED HELP!
its a 93 del sol si. but the guy i got it off of put an ls ecu in it, and it idels high he said it was because it thinks it a bigger motor, but he has the wronge throttle bracket on it so the cable is open more than it should be. if you push it the oppisite way it idels right down so with the right bracket it should idel fine right?
also the raditor fan doesnt work but we pulled it out and hard wired it and it came right on? the ecu is all messed up i need help figuring this out because the fuse and plug on the fan have power, so i have no idea what the problem is. thanks.
Re: wiring mess! NEED HELP!
Try posting in the right forum.
Also try forming complete sentences. Possibly use question marks and list the questions that you have individually instead of in a jumbled pile of dog turds.
also take it to a shop sounds like you need the help of a professional unless you have the etm and factory manual for both cars.
that's what happens when some of these guys buy a honda and suddenly they are honda/acura experts. like the guy you bought your car from.
chris20094
06-15-2006 02:17 PM
rysingsun86
12-20-2005 10:17 AM
