window wiring
Re: window wiring
Which switch, wires, and window(s) are you referring to? Driver, front passenger, left or right rear passenger, wiring, etc.?
Are your meaning you already jumped the switch or are you trying to figure out how to jump the switch. There is also the possibility a switch or window actuator is faulty.
Re: window wiring
As I previously stated, there is also the possibility the window actuator is faulty.
Regardless, unplug the the White 23P harness connector to the driver's door switch. Use a spare piece of wire or small paper clip, insert one end into cavity terminal no. 1 (Blk wire) and the other end into cavity terminal no. 11 (Red/Yel). With another wire or small paper clip, inset one end into cavity terminal no. 10 (Grn/Wht) and the other end into cavity terminal no. 23 (Red/Blk).
Re: window wiring
Would you know where I can get a connector harness for my window switch? My old one is loose and I have to jiggle it to get the window up. Honda wants $130 for it and thats too much ! Maybe you have an idea on how to repair it..The part is: Wire Harness,Driver door-Honda 32751-SDN-A01....Thanks for all your help
Re: window wiring
Salvage yard or ebay for a used one. However, you may be able to keep the connector tight by slipping a zip tie (cable tie) through the area of the locking tab to fill any loose gap.
cksnah252
05-23-2015 09:10 PM
Essenar83
12-14-2007 06:35 AM
