Wheel alignment 2005 accord.
My tires are wearing on the inside on all four corners. It doesn't appear that the camber can be adjusted from the factory. So my question is who makes the best kit to install so the camber can be adjusted??
Re: Wheel alignment 2005 accord.
Caster does not cause the tires to wear, and toe in or out scuffs across the face. Camber is the only thing I'm aware of the could cause the wear on the inside edge.
