Transmission swap
Transmission swap
My 2006 accord 3.0 transmission said good bye after 299,977 miles. I just put in a used one with 116,000. When I first started it up the d was flashing, vsa, abs and check engine lights were on. When I go to drive in d it acts like its slipping but if I use d1 it goes but doesn't shift into 3rd and 4th gears. It doesn't seem to have the same pick up it used to. I went to have codes read but scanner said internal error and couldn't read the codes. I have read posts that said bad pressure switches, tcm , speed sensor, and other possibilities. Just wondering if anyone has these same issues all at once? When I was putting it back together I put some never seize near
the wheel sensor. Could that be part of the problem with vsa and abs lights being on? Any help is deeply appreciated.
blackbeasst
04-27-2013 05:28 AM
