Transmission shifting problems..
2012 Accord Special Edition i4
Symptoms are when shifting from P to R or D the RPM will jump from 1000 to 1500 then shift jerking it into gear, also when coming to stop, the car will stop and then the transmission will catch up seems like and have a subtle jerk. When going from Stop to gas the RPM will jump before the car will go causing it to jerk if i step on the gas hard...
Motor Mounts looks good along with Transmission mounts....I changed both pressure switches, Single Linear Shift Solenoid along with a tranny drain and fill (1x Only...may do 2x more to make it 3x) The fluid was Red and pretty clean, but the symptoms still have not gone away...I am starting to fear the worst as a bad transmission...I will be taking it to check out the programing....
.Can only help? or share your experience?
deerman2701
12-20-2010 10:20 PM
