Transmission Removal replacing clutch PICS
Hey everyone,
Wondering if anyone had some insight on the the proper procedure of replacing a clutch on 2005 Honda accord.
It seems as if there is absolutely no room in wiggle out the transmission, we have very limited room and as such, I'm begining to think that we may need to remove the motor.
Here are the pics.
http://i251.photobucket.com/al...3.jpg
http://i251.photobucket.com/al...0.jpg
See there is very little room between the tranny and the frame.
Not used to this chassis! Any suggestions, even unsubstanciated ones are appreciated. Thanks.
Here are the pics.
Re: Transmission Removal replacing clutch PICS (EG(6)SR)
Did you drop the subframe and remove the driver side wheel? With all of that you should be able to drop the tranny no problem if you're on a lift. If you aren't then you need a cherrypicker to get the engine out. I can't tell from your pictures.
juicy.koreans.suck
12-21-2001 10:53 AM
1990, 1992, 2003, accord, civic, clutch, cost, honda, proceedure, removal, replace, replacing, steps, transmission, trasmission
