Timing Chain 2005 Accord
#27
Re: Timing Chain 2005 Accord
On a pilot that is believable especially if you do new tensioner with every belt. But that would be jamming and still hard to do. I always get a little bigger smile when I see the job is a pilot. I could not agree with you anymore about the right tools making a hard job easy.
#29
I have a 2005 Honda Accord 2.4L 4 cylinder with 5speed manual transmission still running like a dream at 203K miles. I can't say I've ever had a problem with any of the 4 cylinder v tech engines by Honda. However, I've heard some horror stories about the v6.
Any thoughts?
Any thoughts?
#30
Any thoughts?
Any thoughts?
#31
Pretty sure you are talking about the timing belt replacement. It's standard practice to also replace the water pump at that time (easy to get to / when changing cam timing belt and tensioners), and some people also change the oil seals at front of crankshaft and and camshaft ( I might or might not on first 100,000 mile maintenance / yet would change such seals for sure if I saw any sign of a seals leaking oil!) ...
for DIYs, I've notice some well made step by step documentation on internet, including on You Tube. When I do a cam belt, after finding and lining up the marks on camshaft pull and crank pulley (harmonic balancer) to where those marks should be ... I mark the belt and pulleys with a white marker ..a the specific contact next to lining up marks (giving in a service manual for this job) ... and also put arrow on belt twords front of engine. ... then I transfer the marks from old belt to new belt , ... making sure to match teeth counts of both belts exactly. .. this provides a sure way to put your time belt on right the first time. One tooth or rib off on a timing belt is a big headache time suck... that will not let engine run plus require bust down and do it over. ... My two cents.
Retired Bill ...owned a mechanic shop for VWs and the Japanese Auto in the 80s / for preventive maintenance plus engine rebuilds.
#33
#34
I stand corrected. Thought I knew but... just looked up parts supply for 2005 Accord and see timing chain or timing chain kits. If I had to or next time I have to do a timing chain: I still think white marking chain and sprockets after getting all in proper position, and transferring marks from old chain to new chain ... keep track of direction chain is moving/ front vs back back of engine position ... is still a great idea to make sure the timing chain job is done right the first time. One tooth off is a time suck.
ziffies
12
02-08-2013 04:50 PM
garagejunkie
10-12-2009 08:20 PM
