Timing Belt on 06 6-6speed?
Has anyone done the timing belt on their one of the Accord V6 6speeds? I'm asking in particular because I'm needing to either do it or get it done on my 06. I've never done a timing belt before, or anything even similar, but I've yet to find a single shop in my area that I trust, and I'm not looking forward to paying outrageous amounts to get it changed. I have basic mechanical knowledge, and can do a decent bit of work to the cars, but I've never done something like this. I normally do fluid changes, brake work, a/c work, have changed out ball joints, struts, etc. So I'm just wondering if anyone has a write up or directions for this timing belt, and if it's something that a novice backyard mechanic like myself should even try to attempt, or if I should just pony up the cash and pay someone to do it? My biggest fear in addition to paying a ton to get it done, is that they won't really change it, and just charge me for it. Or charge me about 2-3 times what it should cost. Those two things both seem to be common in this area.
Re: Timing Belt on 06 6-6speed?
I plan to do my own timing belt this fall. I posted a link below with a how-to with pictures. It's on an Acura TL but the engines are the same as ours, as far as the timing belt is concerned. I would not depend on the how-to alone, to do the job. I suggest getting a Helm service manual, if you don't have one. Go through all the steps in the service manual, and that should give you some idea if you want to do it yourself or not. Link below
http://tl.acurazine.com/forums/showthread.php?t=695821
I understand where your coming from, but ive been going to the place for years, great work and very trust worthy.
well considering its a close to a 3rd of the normal price i hope so.
like mentioned.. $400 is about the price of parts alone... i would double check they are changing all belts and water pump.. otherwise they arent making any money..
So what parts should I replace here? Anyone have a parts list? A local shop says they will do it for $300 labor, if I bring the Honda parts. I'm thinking of just going this route as I really don't want to mess with it.
Problem is, you don't really know, until you open it up. There could be a leaking tensioner, leaking seals, bad pulley, etc. I already have the belt and the water pump, and I will probably buy a tensioner before I do the job. I'll take my chances with the rest. If you were to buy everything (belt, tensioner, pulleys, seals) you would end up paying $500 or more, just for parts.
If you are gonna do it yourself i would deff buy a new tensioner. I have done many t-belts at my dealership and about 9 out of 10 v6's need one. Its worth buying it just to be safe.
You've convinced me! I will have the tensioner by the time I do it. How about valve adjustment? Is it needed, even if they don't make noise?
You dont have to adjust them, but if your changing the belt, Im guessing the mileage is 90k+
so it would be a good idea too. Here are the specs
Valve Clearance
Intake:
0.20-0.24 mm (0.008-0.009 in.)
Exhaust:
0.28-0.32 mm (0.011-0.013 in.)
Valve Clearance
Intake:
Exhaust:
Yes. A tight valve will not make any noise, and that is generally what happens to Honda valves, they tighten up. Allowing this condition to occur for too long will cause valve damage initially and then head damage.
Thanks guys. I called a local shop finally this morning that specializes in Honda's and uses only Honda parts, and I got quoted $840 for them to do it with changing the adjuster. I made an appointment for tomorrow as everywhere else I called is going to be more it seems.
They recommended I not change the tensioner and it's $120 of that, but after reading on here, I feel I really should. They said they have done tons of them and they have only ever replaced 2 tensioners.
The other thing they aren't changing is the pulleys. They said that there is absolutely no reason to replace the pulleys and that they don't hardly ever go bad. Do you think I should listen to this, or should I make them do the pulleys while in there?
safedriver
Acura TL, RL & ZDX
05-22-2016 06:29 AM
