Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Starting problem
Old 07-27-2013, 12:35 PM
brian3222's Avatar
Default Starting problem
2007 accord 4 cyl automatic 55 k miles
I have been having mysterious starting issues:
every 50 or so starts, turn to crank it--- dash lights all come on like supposed to but nothing when I crank it, flick key back do it again and she cranks and starts. ( all battery terminals and wires have been checked and rechecked for corrosion/loose). The battery checks out as OK with a load test, could it be the cold crank amps are just barely enough? This happens at all temperatures: winter, summer, etc.
Battery:
CCA at O degress: 450 at 32 degees 560 , it's the stock sized battery for the car, new 9 months ago.
Could it be it's just barely enough "oomph" to turn the starter over?
I just can't believe at 55 k miles this car needs a starter.
Old 08-05-2013, 04:11 PM
shrekfiona's Avatar
Default Re: Starting problem
I had the exact same issue at 104K. All the electronic gizmos(power windows, radio, lights) worked fine but no ignition. My car was a manual so I could do the old push start and car would work fine. Battery checked out fine. The Honda service center tells me that the starter is the one that needs changing. I am honestly surprised that a car at 55K needs a new starter.
shrpsh00ter
11-14-2012 08:52 PM
mysticstylezrx8
24
04-14-2011 09:40 AM
HI91EFHB
11-01-2009 06:46 PM
brzrkr
11-25-2007 03:51 PM
solk1dd
07-23-2007 06:25 PM
Quick Reply: Starting problem
