spark plug change
spark plug change
my 03 honda accord has 80k miles so i decided to change the spark plugs, gapped it and now the engine light comes on every once in a while and sometimes it sputters. what can i check? i did everything by the books
Re: spark plug change
Make sure all your coil wire connections are tight. The plugs should not need to be gapped. The stock irridium plugs (Denso NGK) should come pre-gapped, and should not be adjusted. Did you tourque the plugs down to 13ft lbs (I think)?
thanks for the reply
yes, the ngk was torqued to 13 lbs and i air cleaned all the electrical connectors
you can feel a slight miss firing on idle at times and when i accelerate, sometimes it sputters
Was it doing this (miss-fire sputter) before the spark plug change? If not I would re-do everything, and make sure one of the plugs were not damaged during install. If it's a 4 cylinder it should be pretty easy to re-do, V6 not quite as easy.
everything was smooth before, ran very smooth.
took it to autozone . . . hooked up the computer tool and it read fine
wondering if the 13lbs on the torque wrench was wrong, meaning that i didnt tighten enough or tightened too much
air cleaned the electrical connectors , a 4cyl.
the sputter seems slight on idle but when i accelerate you can notice and sometimes the engine light comes on
Great! Glad you got it. Were the EBay plugs the correct number? If they were, they should have had the correct gap right out of the box. I wonder if these same plugs (same number) are used on other cars, with different gaps. I've heard that gapping the irridium plugs can easily break the small tips.
If you've ever looked at an irridium plug, the tips are very small, and while the irridium may be a harder metal, that also means it is more brittle and doesn't bend like softer metals do. I'm no expert on spark plug material, but I assume that's why they say not to adjust the gap on irridium plugs, like you would other plugs.
W95civicEXcoupe
11
10-27-2014 10:01 AM
