slight misfire
slight misfire
So When I am cruising at about 40 mph and barely pressing the gas to maintain the speed it starts having like a misfire like effect around 2000-2300 rpm's anyone ever seen this its a auto trans 2003 accord lx all stock its only at 40 mph and 2000-2300 rpm
Re: slight misfire
Almost sounds like an egr issue?
Does this only happen when the car is at normal op temp (closed loop)?
Pull the egr chamber plate off the injector base and have a look - #12 is the cover, #13 is the gasket.
