Shifter stuck in park -- help - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 07-07-2009, 07:28 AM   #1
New User
Icon6 Shifter stuck in park -- help
I have a 2005 Accord EX 4cyl. The shifter is stuck in park, must use the shift release to shift out of park.
I have already checked the brake switch and it is good.
I checked the shift release solenoid at the gear shift and it is good.
I thought the problem might be the throttle position sensor. I tested the output voltage of the tps and it is 0.5 volts closed and ~4.5 volts at WOT which I believe is the correct reading.
Now the strange thing is that if I unplug the throttle position sensor, the shift lock release works fine. As soon as I plug the tps in again, the shifter doesn't release again. Can anyone help? Thanks!
elicht is offline   Reply With Quote
Old 07-12-2009, 12:48 AM   #2
striker81's Avatar
Default Re: Shifter stuck in park -- help
Do yo have a hayne's manual, or have you checked the dealership?
striker81 is offline   Reply With Quote
Old 07-12-2009, 03:15 PM   #3
KWayRacing's Avatar
This happens all the time or is it intermittent?
KWayRacing is offline   Reply With Quote
Old 07-12-2009, 03:23 PM   #4
PyroProblem's Avatar
Can you audibly hear the lock solenoid operate everytime you press on the brake?
If not, you need to check for available voltage at the solenoid which means you have to remove the console.
Any signs of liquid intrusion? Soda or coffee spills? This seems to happen alot...
Refresh my memory if you can, 05 accord= Drive by wire/ E-throttle?
If so, id say the TPS thing is a normal backup/failsafe for the ecu.
Is your Brake switch a 4 pin/wire switch?
PyroProblem is offline   Reply With Quote
06 Honda Element Stuck in Park Nikki Bombek Honda Element & CR-V 7 09-03-2016 12:00 PM
What Shift Interlock Solenoid Part Number...? NorthCountry Honda Accord (1990 - 2002) 6 08-21-2015 06:22 AM
2003 Honda Accord Throttle Position Sensor (TPS) jjknott82 Honda Accord & Crosstour (2003 - 2012) 2 12-22-2014 12:04 PM
03 Accord 2.4 cpe, shift interlock solenoid not working euroticcustoms Honda Accord & Crosstour (2003 - 2012) 5 02-16-2013 02:17 PM
Problem with TPS Throttle Position Sensor and Shift Lock 99 TL bubba1234 Acura TL, RL & ZDX 8 05-30-2010 08:56 PM
Tags
2005, accord, acura, fit, gear, honda, lock, odyssey, park, problem, release, shift, shifter, stuck, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
