Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Help 2005 Accord
Old 12-14-2009, 07:40 PM
lut1dav's Avatar
Default Help 2005 Accord
I have 2005 accord 4cy the battery whent dead .got a new one put it in now theres nothing no lights when you turn the key on not any lights come on its like its all dead do you think it could be the ecm?? or fuze? im stuck. Thanks Dave.
Old 12-14-2009, 07:45 PM
Matt55's Avatar
Default Re: Help 2005 Accord
main relay
Old 12-14-2009, 07:51 PM
lut1dav's Avatar
Originally Posted by Matt55
main relay
Thanks ALOT DAVE
Old 12-14-2009, 07:54 PM
Matt55's Avatar
who is dave? or did you mean thanks alot, dave
Old 12-14-2009, 07:56 PM
redbull-1's Avatar
Main relay wouldn't usually cause no lights, etc.
Check the battery connections first then the underhood fuses next.
Old 12-14-2009, 07:59 PM
lut1dav's Avatar
[QUOTE=Matt55;40950543]who is dave? or did you mean thanks alot, dave[/QUOTE
THANKS ALOT, FROM DAVE
Old 12-14-2009, 08:00 PM
lut1dav's Avatar
I'LL CHECK THAT TOO, THANK YOU!
Old 12-15-2009, 06:14 AM
Old Member
GoLowDrew's Avatar
Where did you get the battery? Does it look like there is turnover? When was the battery made? Do you know if it's even good? Did they "test it" before they hand it to you?
Old 12-15-2009, 12:58 PM
lut1dav's Avatar
It was the battery relay
Old 12-15-2009, 05:43 PM
redbull-1's Avatar
You probably mean the battery fuse (power distribution) in the under hood fuse box, instead of relay.
Old 12-15-2009, 07:50 PM
lut1dav's Avatar
Thats it
Dawn Peterson
03-07-2016 05:47 PM
hrobertson1
07-06-2014 03:00 PM
dings35
Honda CR-V & Element
05-27-2013 06:23 PM
wood181
04-15-2008 06:59 PM
squirrelgripper
08-21-2007 11:27 PM
Quick Reply: Help 2005 Accord
