Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Replacing 2004 accord radio
Old 12-30-2007, 04:35 AM
jimborod's Avatar
Default Replacing 2004 accord radio
I have a 2004 Accord LX 4 cyl the current radio is a 39050-sda-a010; which is a regular cd player. I bought a 39100-s82-a300; which is a cd changer and dual air.
Will this work? I only have two plugs a blue plug for the radio and a green plug for the air conditioner, I noticed the green conncetor on the new radio is inverted and it has an additional conncetor on the opposite side. Do I need more cables or this won't work.
Old 12-30-2007, 07:16 AM
BLKFLSH's Avatar
Default Re: Replacing 2004 accord radio (jimborod)
For dual climate control to work, there has to be temperature sensors on both sides of the interior, plus the wiring to go with it.
Old 01-01-2008, 05:36 PM
SurfDan5's Avatar
How come your swaping out the radio? If its to install a system there are plenty of adaptors on the market that work. I use a JL Audio CLean Sweep for my system incase that helps...
Old 01-02-2008, 05:31 AM
mdh061's Avatar
I dont mean to change the topic of this thread but more or less just looking for a quick answer. I kept my head unit and added new speakers and a subwoofer along with a kit to have RCA cables... ever since my FM radio has been getting extreme static..
Is there quick fix to this ? Maybe a bad hookup on my part ?
Old 01-02-2008, 07:34 AM
SpooN Man's Avatar
Default Re: (mdh061)
Check your grounds. You could be having issues after adding the rca connections.
Old 11-29-2008, 09:01 PM
djz06's Avatar
I was wondering if you ever found a answer to your question? I bought a 6 dics with dual and having the same peoblem you had...
Old 11-29-2008, 10:17 PM
stereo69's Avatar
what you need a 6 disc radio from a single climate control car since your doesn't have dual climate thats what the extra plug is most likely for it might cause problems ...
Old 11-29-2008, 10:21 PM
djz06's Avatar
Default 6 dics with dual climate...
I was hoping that maybe the other person that had the same problem found a way to fix it... Thanks for getting back to me so fast...
Dj
Old 11-30-2008, 10:41 AM
djz06's Avatar
Does anyone have a picture or wire diaagram on the pins of the two green plugs for a dual climate control ? On a 06 Accord...
jimborod
Audio / Security / Video
10-02-2015 01:46 PM
crxaddikt
09-11-2015 10:04 PM
novanuttz
05-12-2006 06:46 PM
Quick Reply: Replacing 2004 accord radio
