Remote door locks
Remote door locks
I've tried I search and can't seem to find my exact problem.
I picked up a 2003 accord coupe, V6 with a 6 speed manual transmission.
I have few problems and would like some input.
1. My remote does not lock or unlock either door. When I press either button the lock rod on the driver side (the only one I have watched) moves a little bit but does not unlock or lock. If I hold the unlock button the Windows go down but the doors are still locked. The truck button on the key works normal and opens the trunk every time. The lock/unlock buttons inside the car work as designed.
2. When I first start the car my navigation screen comes up and has an Acura logo on it. There are times I don't press the "Ok" button and the screen goes black and is unusable. Not sure if this is normal or not.
3. I'm getting a 3rd gear grind (i've read this may be common) but when the car is cold and a rumble in 5th gear at all times, that can be felt and heard.
4. In first gear accelerating normal from a stop in getting a knocking/ticking type noise that increases frequency as speed increases. Its not a rod or wrist pin type knock it seems to be coming from the left front.
I have found the post about fixing the drivers seat that rocks forward and back when accelerating and braking. I'm sure I'll find more things to ask but as of right now these are the issues that are annoying me.
My apologies if these have been covered but I don't want to chase a problem that someone has had that's similar but not exact and is not my issue.
snapplez
07-27-2013 04:23 PM
