question!! '04 accord v6 coupe radio light
The radio light/A.C. light on my accord blew out. When i drive at night it's really dark inside and i can't see if my AC is on or off. I have no idea where it's at to replace it and what kind of bulb it is. Does anyone on here have any idea how it's look like and where it's at?
Thanks so much!
Re: question!! '04 accord v6 coupe radio light (rideimport)
If you have an late 2003/early 2004 accord there have been huge problems wiht the radios. I had mine changed about a year ago. It was spitting out CDs and then the screen went black. If this is the case call your local Honda Dealership, and bitch and moan until they give you a new one.
Just google search accord raido problems and you'll get tons of poeple complaining.
Another thing, is if you hold down the CD/AUX for 15 seconds or so it makes the screen go black. it makes a beep sound, so this might have been pressed accidently. Similarily if you hold it down again for 15 or so seconds it will light back up. But my guess it is the earlier problem.
http://www.carcomplaints.com/H...shtml
do you have NAV? I do and the screen up in the dash does this and I can't find a solution since the TSB says it only applies to non-NAV cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rideimport »</TD></TR><TR><TD CLASS="quote">
Thanks so much!
Take it to a dealership, as long as it is not nav they have extend the warranty on the PCB (Printed Circuit Boards) part of the board shorts causing the screen to dim. Also im not sure of your milage but I believe its covered to 108K
Thanks so much!
Re: question!! '04 accord v6 coupe radio light (MustangLX6.0)
thanks a lot for all of the replies. I'll try checking w/the dealership.
Its at 67,000 miles. No nav.
joshwairi
Thanks, i'll try holding cd/aux and see if the screen will come back on.
The cd/radio still works it just no light!!!!!
Thanks again.
joshwairi
Thanks again.
SEANG1025
02-27-2019 09:50 AM
