PLEASE HELP!!! 03 V6 Coupe 6spd won't idle!
I have a 2003 Accord V6 Coupe 6spd and it won't idle!!!
Once I start it, it runs normally then once I touch the gas it will shut off.
I can drive/shift it normally as long as I don't let off the gas.
I had the shop replace my exhaust rocker on the rear head because they broke when I miss-shifted.
What could be wrong guys?!?!?
Re: PLEASE HELP!!! 03 V6 Coupe 6spd won't idle!
The tech said the engine is stuck in vtec... how do I fix this?
replace the vtec solenoid?
very strange sounds like they installed something incorrectly. so what is the check engine light doing?
so you had bent or broken valves correct ?
There were no bent valves. Just broken exhaust rocker on the rear head.
Check engine light isn't on. Car just dies if I let off the gas.
