Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Accord & Crosstour (2003 - 2012) (https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/)
-   -   Please give me an idea how to remove it. (https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/please-give-me-idea-how-remove-3334209/)
T T 02-22-2019 11:34 PM
I have a Honda accord 2009. Recently there is an oil leak between the joint of the power steering return hose (OEM part number, 53734-TA0-A01) goes into the pipe under the part Honda called,
"Rear engine mount upper bracket" (OEM part number, 50685-TA0-A00). In order to replace the hose, I need to remove the rear engine mount upper bracket before getting under to reach for the joints because the hose is connecting into the pipe hide under the bracket. But I need some of you give me a good idea which way would be the best and how to remove it. It would be very appreciated and thank you very much in advance.
Sincerely,
Tony
