Pinging 03 Accord V6
I think I'm hearing pinging when I go up a slight incline and I climb at a steady speed. Maybe 25 - 35% throttle.
Or even when I accelerate moderately.
I don't seem to hear it at all when on the freeway, but only when at moderate speeds, and seemingly with only a less than 50% throttle use.
Is this really pinging? It's a high pitched ringing sound, but I'm just not sure.
Thanks!
Thanks!
be professional
Re: Pinging 03 Accord V6
Could be.
Have you checked to make sure none of the exhaust shields are rattling? The intermediate shaft shield?
Have you tried running a higher octane fuel to see if the noise goes away? An engine that pings lightly on 87 will usually be cured with 89 or 91 octane.
I will give the higher octane a try and report back.
If it is pinging a few maintenance area's to look at are water temps (thermo , radiator and fans), EGR operation (not plugged/caked up passages) and possible carbon build up .
irocmcgradys
06-30-2006 03:44 AM
