P1157 code
P1157 code
My 2006 Honda Accord with 2.4 engine seems to be running fine but the engine light is on. I took it to an Auto Store and borrowed their scanner which displayed a P1157 dtc. Searching the code list, it looks like the upstream A/F sensor possibly has failed.
Is there anything else I should check before replacing this part?
Should I only use Denso sensor? Any idea of the OEM part #?
Where is it located and how hard is it to replace?
Re: P1157 code
Its pretty easy to replace. Make sure you use oem parts with your vin number to verify its the right part. Its about 120 bucks.
mrchaikel
05-28-2006 06:15 PM
arielb1
07-22-2004 05:40 PM
