P0301 code in Honda accord LX2012
2012 honda accord LX Mis fire P301, I replaced all injectors, Coils and spark plugs, compression is good still code p301 shown up
Re: P0301 code in Honda accord LX2012
You got leaks. Oil is leaking into the spark plug well. Did you see any oil residue on the coil when you replaced the sparks?
No there is no oil leak,no Vaccum Leak. but I found fuel injector is bed. Thanks
I have othercar Honda Civic 2015 Manual Transmission. I replaced unother engine due tocar run in water. then Car won't start with No crank, starter good all light on.Is there any solution?
Originally Posted by drewamin
(Post 51789599)
Originally Posted by MazVilla
(Post 51786784)
