Orange wrench shaped light??? - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 03-30-2012, 04:58 PM   #1
Default Orange wrench shaped light???
Hey gang,
I have an 07' Accord and just a couple hours ago, the orange wrench shaped light came on the dash... Does anyone know what this is from or for and what do I do? I plugged in my OBD2 reader and no codes came up, so I'm clean with that. Any help would be greatly appreciated. Thanks....
Newbie808 is offline   Reply With Quote
Old 03-30-2012, 07:27 PM   #2
Default Re: Orange wrench shaped light???
Ok, found out that it's the oil change service light. All I did was pres in the reset button till it showed the oil's life was at 15%. Then pressed the button in again, until the oil's life 15% was blinking, let go of the button, turned on the engine, then press the button again till it reads 100%. Damn that was simple...
Old 03-30-2012, 08:06 PM   #3
bgdriver's Avatar
you still have to actually change the oil..... just resetting the light doesn't do anything.
bgdriver is offline   Reply With Quote
Old 04-02-2012, 12:02 AM   #4
Actually, I changed the oil about 600miles ago, but never knew there was a oil light on this car. This is my first Honda, so I'm still bumping around in the dark and learning as I'm going along..
Spanner wrench for coilovers Larz Honda CRX / EF Civic (1988 - 1991) 2 06-03-2007 08:04 PM
Flare wrench for brake lines... unknown0001 Honda Civic / Del Sol (1992 - 2000) 13 08-28-2005 05:41 AM
Impact Wrench for suspension bolts 94CoupeEJ1 Honda Civic / Del Sol (1992 - 2000) 19 06-02-2005 06:04 PM
oil filter wrench size envious1320 Acura Integra 11 04-07-2003 07:29 AM
Problem with new wheels and lug nuts 95GS-R Acura Integra 28 03-12-2002 09:47 AM
Tags
2007, 2012, accord, civic, dash, dashboard, element, fit, honda, light, odyssey, orange, pilot, reset, service, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
