Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
oil light/ wrench will not reset!! Tried it all!!!!
Old 04-04-2010, 10:55 AM
TRIAL USER
Icon6 oil light/ wrench will not reset!! Tried it all!!!!
I have tried everything possible... the directions in the manual, and searched forums, online etc... My mileage has now reached -6545.. I can't reset it. I have a 2007 honda accord hybrid.... anyone who may have experienced this problem I would love to hear from.. I contacted dealer and they said same as manual..still wont reset...any ideas?????
Thanks
herbedout13 is offline
Old 04-04-2010, 12:08 PM
90sedan's Avatar
Default Re: oil light/ wrench will not reset!! Tried it all!!!!
Honestly, you probably just aren't doing it correctly.
-With the Key on or the car running in Park/neutral, press the odometer button on the gauge cluster till it scrolls to the oil life percentage.
-Once there, hold the button down for ~10 seconds till it begins to flash.
- release the button and hold it down again for ~5 seconds. The oil life indicator should reset itself.
How many miles are on it? Since its an 07, I'm sure it's been reset before.
90sedan is offline
Old 04-04-2010, 12:47 PM
TRIAL USER
hey, their are about 54000 miles on it and yes actually I have reset it numerous times before..its rather easy...thats why I dont get it now and decided to make a post about it...I have also had three seperate tire/lube places try but cant seem to do it either...thanks for ur input
Old 04-04-2010, 12:55 PM
TRIAL USER
stylpntbil's Avatar
hes right the only reason it would not reset is you are not doing it right unless your button for your trip reset is broken
and what warning light is on is it service a ?
stylpntbil is offline
Old 04-04-2010, 01:43 PM
TRIAL USER
It's on service A 12. I am sure I'm doing it 100% correct. Even the mechanics couldn't get it off.
Old 04-04-2010, 02:47 PM
KWayRacing's Avatar
Are your headlights in the auto position? If so turn them off and then try.
KWayRacing is offline
Old 04-04-2010, 04:04 PM
make sure u r headlights are off
it's a security feature to prevent drivers from resetting the maintenance minder while drivin
kotomoto is offline
Old 01-08-2016, 03:16 PM
Did u figure this out yet??? I have the same problem with my 2010 Pilot....these morons keep telling us how to reset the oil percentage light!!! I've done that several times before. This wrench is on with negative mileage shown for overdue A service. Do I have to go to dealership??? Thanks.
MartelEnt is offline
Old 01-08-2016, 03:44 PM
Wild shot....are you trying this with the drivers door closed?
poorman212 is offline
Old 01-08-2016, 03:52 PM
I think it finally worked!!!! Thanks!
Old 01-08-2016, 04:45 PM
Wishing the best and hope all is well.
Old 01-08-2016, 04:47 PM
Guess I'm the moron....sorry guys!!!
Old 05-20-2018, 03:39 PM
I dont see that anyone actually answered the question, so: my 2010 Honda Accord oil life would not reset. I repeatedly attempted to follow the standard procedure posted here in and it did not work; the oil life simply flashed "service" with a negative number. I continued to turn on the ignition and then press and hold the reset light until it blinked approximately 20 times; I tried this several times (sometimes crank sometimes just the ignition) and eventually it reset to 100%
Alan Williams is offline
Old 07-10-2018, 11:52 AM
I had the same issue. Beleive it or not, I changed the position of my lights from Auto to Off and then retried the sequence. It worked! Who would have "thunk" it!
Robert Jones is offline
Old 05-16-2019, 07:17 AM
I have a 2007 Honda Accord Hybrid. I bought it about a year ago and the oil life has always been in the negatives. Iíve tried everything. Took it to Honda and other places. I canít figured it out. My car does not have automatic headlights. I can deal with it. But itís annoying. It just flashes -9999 at me when I turn my car on.
dustychopper is offline
RonnieB84
09-07-2017 04:42 PM
luis_ej8
Honda Fit
12
03-08-2017 01:39 PM
BoostAndBoobs
04-21-2016 04:53 AM
bal
04-03-2016 07:20 PM
bal
04-03-2016 07:12 PM
Quick Reply: oil light/ wrench will not reset!! Tried it all!!!!
  • Ask a Question
Question Title:
Description:
