Help Removing 03 Coupe Lock Actuator
Well, I believe I have the usual door lock actuator failure. I have a new actuator waiting to go in and got the door panel off.
I can see and touch the actuator, but how does it come out? Do I need to remove the latch? If so, is there a trick to removing the 3 screws around the latch? Mine seem like they don't want to budge because they're overtightened or locktighted?
Thanks for newbie help.
Re: Help Removing 03 Coupe Lock Actuator
You shouldn't have to remove the door latch. If you have already removed the door panel then try removing the door glass inner weatherstrip from the door panel by pulling it down.
From this point in time, you should be able to spot an electrical connector. All you have to do is disconnect the electrical connector and remove the door actuator:
*diagram courtesy of hondapartsnow.com; all rights reserved
Frstyl838
07-10-2008 12:34 PM
killaj12
11
05-06-2007 02:38 PM
