Newbie Running Wires 2008 Coupe
THis forum has been a lot of help so I finally signed up. Shame on me I know.
I have a 2008 Accord Coupe EX-L and I love it. It replaced a 2004 EX Sedan...
While I am no stranger to wiring and vehicle electronics, mainly emergency related stuff, I need some help getting 3 wires from a switch box in my car to the front compartment (for a siren speaker and headlight flasher)
I am trying to run 3 wires from switches in my car to the front of the car, is there an easy access or do I have to make one myself? I can't find any obvious access points.... Help?
Re: Newbie Running Wires 2008 Coupe
Usually the drivers firewall is the best place but, sometimes you can find a place down low on the passengers firewall if you have to. If you don't have a push-thru tool like this: then cut a small slit in one of the grommets and push them thru or use a wire fish (fishe?). If you can't find a suitable grommet then use a small hole-saw to make your own hole. *Use a grommet in your hole or the metal with eventually cut thru the wire insulation and cause shorts. Tape the wires together to make them easier to pull thru. Also, make sure to cover the hole in the grommet or hole you made with silicon so you don't get water in the car.
tundra2000
07-03-2011 09:53 PM
