New Guy with 06 accord and a question
Hi All, first of all Hello.
I just bought and 06 exl accord v6 for my daily driver. So far, I absolutely love it. It has 19k miles on it, and its a Honda certified. My only issue with this car...and its driving me absolutely crazy, Its a noise that I thought to be spark knock, but after listening for a week, Im certain its not.
The noise sounds like its comming from underneath the car, and happens upon accelleration. Its a light metallic clanging sound, and it typicallly goes away above 3k RPMs. Its a serious downer b/c the car is so smooth, and so nice, but its sounds worse than my 99 jeep with 180k sounded b4 getting rid of it. Ive been searching online, havent found much. Have any of you heard of this issus? TY, Chris.
Re: New Guy with 06 accord and a question
Since ur car is certified take it back to the dealer and tell them the problem, and see if they can figure it out...
In a Junkyard near you.
Service Bulletin
© 2008 American Honda Motor Co., Inc. – All Rights Reserved ATB 34342-38727 (0802) 1 of 5
CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment,
and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume
this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an
authorized Honda automobile dealer.
February 8, 2008
07-028
Applies To: See VEHICLES AFFECTED
Pinging, Rattling, or Squealing During Light Acceleration
(Supersedes 07-028, dated November 20, 2007, to update the information marked by the black bar)
SYMPTOM
While driving under light acceleration, you hear an
intermittent pinging, rattling, or squealing from the
engine compartment. The noise can easily be mistaken
for an engine ping or spark knock. In some cases, the
noise happens only during engine warm up.
PROBABLE CAUSE
The intermediate shaft heat shield is loose in its
mounting bushings.
CORRECTIVE ACTION
Replace the intermediate shaft heat shield and, if
needed, any specified nuts or gaskets.
VEHICLES AFFECTED
2003–06 Accord V6 A/T 2-door and 4-door: ALL
2007 Accord V6 A/T 2-door:
FromVIN 1HGCM82..7A000001
thru 1HGCM82..7A001041
2007 Accord V6 A/T 4-door:
FromVIN 1HGCM6...7A000001
thru 1HGCM6...7A023040
2006 Accord V6 M/T 2-door and 4-door: ALL
2007 Accord V6 M/T 2-door:
From VIN 1HGCM81..7A000001
thru 1HGCM81..7A001161
2007 Accord V6 M/T 4-door:
From VIN 1HGCM65..7A000001
thru 1HGCM65..7A024862
2005 Accord Hybrid: ALL
2006 Accord Hybrid:
From VIN JHMCN3...6C000001
thru JHMCN3...6C003948
2005–06 Odyssey: ALL
2007 Odyssey:
From VIN 5FNRL3...7B000001
thru 5FNRL3...7B007592
From VIN 5FNRL3...7B400001
thru 5FNRL3...7B405900
2005–06 Pilot: ALL
2007 Pilot 2WD:
From VIN 5FNYF2...7B000001
thru 5FNYF2...7B006445
2007 Pilot 4WD:
From VIN 5FNYF1...7B000001
thru 5FNYF1...7B002578
2006 Ridgeline: ALL
2007 Ridgeline:
From VIN 2HJYK1...7H500001
thru 2HJYK1...7H504020
PARTS INFORMATION
Intermediate Shaft Heat Shield:
All except Pilot –
P/N 44517-SDB-A00, H/C 7247851
Pilot – P/N 44517-S9V-A00, H/C 8159105
Exhaust Pipe A Front Gasket (2 required):
P/N 18212-SA7-003, H/C 1462290
Exhaust Pipe A Rear Gasket:
P/N 18393-SDB-A00, H/C 7245194
Self-Locking Nut (9 required):
P/N 90212-SA5-003, H/C 1169812
Spindle Nut:
Pilot, Ridgeline only –
P/N 90305-S3V-A11, H/C 7196116
Damper Bolt (2 required):
Pilot only –
P/N 90119-S0X-A00, H/C 5943758
Ridgeline only –
P/N 90119-SJC-A00, H/C 7942501
Damper Nut (2 required):
Pilot only –
P/N 90382-SP0-003, H/C 3675121
Ridgeline only –
P/N 90381-SJC-A00, H/C 7942626
February 8, 2008
07-028
SYMPTOM
PROBABLE CAUSE
mounting bushings.
CORRECTIVE ACTION
VEHICLES AFFECTED
2006 Accord Hybrid:
2007 Odyssey:
2005–06 Pilot: ALL
2007 Pilot 2WD:
2007 Pilot 4WD:
2006 Ridgeline: ALL
2007 Ridgeline:
PARTS INFORMATION
All except Pilot –
Spindle Nut:
Pilot only –
Ridgeline only –
Pilot only –
Ridgeline only –
H-T Order of Merit
The six cylinder's injectors can also be noisy enough that people think that there is something wrong w/the car.
The injectors clicking, is the only sound I hear from my engine. Everything else is so smooth it's hard to believe it will stay that way. 65k miles so far, and as smooth as ever. The injectors seem to quiet down after the engine warms up. Some people probably mistake this for ticking valves.
wow, thanx guys. One of my friends suspected the heat shield, bc the noise is not exactly from the engine. I took it to Honda, they just hooked it up to the computer and said everything was within spec. Im going to bring the bulletin and make them listen to the noise.
ty
ty
exl6ing
04-18-2014 12:40 PM
Kellnos
08-03-2005 10:03 AM
