Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Manufacturer recommended schedule for transmission fluid?
Old 04-15-2008, 09:57 PM
97GSR's Avatar
Default Manufacturer recommended schedule for transmission fluid?
Can anyone tell me when Honda recommends you to change the transmission fluid?
Reason I ask is I am planning to get a 03 V6 and I have heard of some tranny issues. But from what I have read, by changing the tranny fluid at least every 15k-30k, I should be ok.
Now if I purchase an 03 that has around 60k and it was taken in for routine maintenance, would they be changing the tranny fluid so often?
Old 05-13-2008, 08:04 AM
hometheaterman's Avatar
Default Re: Manufacturer recommended schedule for transmission fluid? (97GSR)
At our local dealer it was part of the 30k mile service. This was on a 06 V6 6speed.
Old 05-13-2008, 07:15 PM
Accord1234's Avatar
Default Re: Manufacturer recommended schedule for transmission fluid? (hometheaterman)
If it has more then 50K and never been changed, changing will do more harm then good.
Old 05-13-2008, 07:32 PM
BLKFLSH's Avatar
Each dealership is different, but I think they would have at least checked the condition of the fluid. Test drive the car for issues, but you should be ok. My 03 V6 is doing fine at 54k miles, but I've changed out 3 quarts every 15k miles. The schedule in the owner's manual says 120k miles, but there's no way I would wait that long.
Modified by BLKFLSH at 10:38 PM 5/13/2008
Old 05-16-2008, 02:58 PM
vapor40's Avatar
We do it every 30k I think the books shows it less often but as you said some of these have had issues.
Old 05-18-2008, 02:35 PM
CBL9's Avatar
Default Re: Manufacturer recommended schedule for transmission fluid? (Accord1234)
Thats not proven to be true at all.
I had a hard shifting Automatic 89 Civic Sedan w/ 120K on it. Changed the fluid I had never seen that amount of sludge on any Honda magnetic filler bolt. I filled it up with OEM Honda ATF. Drove the car for 1K miles, and changed it again. More shavings came out. Kept changing it @ 15K miles, and totaled the car at 255K miles two years ago.
To the OP:
Get car, then drain and refill.
Drive 1K miles, then do it again.
Change it every 15K miles after that.
Old 05-18-2008, 04:25 PM
Smitdog's Avatar
Default Re: Manufacturer recommended schedule for transmission fluid? (CBL9)
At my workplace (Honda Dealer) we change the trans fuild every 30. The most problimatic Accord trans are the 99-01 v6 trans. That is why Honda extended the warranty on these units. With the reputation this trans have built we also recommend more often fuild trans just to be on the safe side. But "to each their own"
Old 06-13-2008, 09:42 AM
bracer's Avatar
Default Re: Manufacturer recommended schedule for transmission fluid? (Smitdog)
Smitdog: please read my recent post about 2003 Honda Accord V6 timing belt
Tmilli55
Honda CR-V & Element
09-26-2018 01:27 PM
dankoty
11
01-08-2017 03:38 PM
aries331
12-01-2007 01:13 PM
stickercuttingcom
01-19-2006 04:08 AM
Googs16
09-15-2004 03:02 PM
Quick Reply: Manufacturer recommended schedule for transmission fluid?
