If there is a Crosstour owner on HT, I have a quick question
Old Member
Thanks.
Or if you work at a Honda dealership, also.
Please tell me the measurements of the Crosstour exhaust tip OEM.
Width
Height
TIA
Width
Height
TIA
Re: If there is a Crosstour owner on HT, I have a quick question
http://automobiles.honda.com/accord-...fications.aspx
Exterior Measurements
EX--EX-L
Wheelbase (in)110.1 110.1
Length (in)196.8 196.8
Height (in)65.7 65.7
Width (in)74.7 74.7
Track (in, front/rear)64.9 / 64.9 64.9 / 64.9
Ground Clearance (in, unladen)8.1 8.1
Curb Weight (lbs, 2WD/4WD)3852 / NA 3887 / 4070
Weight Distribution (2WD; %, front/rear)59 / 41 58 / 42
Weight Distribution (4WD; %, front/rear)NA 57 / 43
Towing Capacity (lbs)1500[3] 1500[3]
EX--EX-L
Width (in)74.7 74.7
My Name is Nobody
you know... it looks just like our accord v6 muf/back. I really dont see any differences, though there could be in routing. if anything, those tips look to have a slight 2-5% downward tilt to them that the accord does not, but that's just from the pict
The width is approx 11.5cm
The height was tuff because of the angle of the tip but approx 8cm
I agree though, they look to be identical to regular V6 Accords.
They look similar but the Crosstour tips are actually narrower and (i think) a bit longer. i dont know the exact dimensions of the accord one but i can tell you they are different. i work at a honda dealership prepping all the new cars and i have eyeballed quite a few crosstours.
Old Member
The Accord tips are 5" wide and 3.5" tall, so the Corsstour is a bit smaller. I just thought the angle tip (of the CT) would look better.
Thanks guys.
Thanks guys.
JSTOCK
20
02-28-2003 05:06 PM
